Can I replace any receptacle with a GFCI?
Can I replace any receptacle with a GFCI or are there special considerations? I have an outlet in my yard which gets wet from my sprinklers. I want to replace it with a GFCI.
Thanks
Thanks
Yes you can..and that outlet should have a GFCI installed since its getting wet. I presume that box is an outdoor box with a waterproof cover? If not, it should be. Is this outlet the one youre considering to power your pond pump?
