Installing a dryer Outlet
Old 03-27-04, 03:25 PM
tim hector
I'm living in an old house (built in the 60's, I think), and the basement has limited electricity. I would like to install a 3 prong 220V dryer outlet in the basement. I was considering wiring it from where our Range outlet is wired, from upstairs. I'm wondering if this is safe to do? If I did this, would it be dangerous to have the range and the dryer going at the same time, or would the fuses just blow?
thanks in advance.
-tim
Old 03-27-04, 04:01 PM
thefixitman
Re: Installing a dryer Outlet
You must install a 4 prong receptacle using 3 wire plus ground.
No it is not safe since most likely the range circuit is too large for the dryers needs. Even if it is not too large of a circuit for the dryer, it would be a code violation because the circuit was designed for only the range and is maxed out.
