Ceiling fan making a humming noise
Old 03-27-04, 02:29 PM
carlosmlr
Question Ceiling fan making a humming noise
When I turn on the lights of the ceiling fan using the dimmer, there is no buzzing and all is well...
But when I turn on the fan by pulling the chain the fan produces a humming noise??
It is not specific to this room and the fact that it is on a dimmer, because in another bedroom there is no dimmer and that ceiling fan also makes this humming noise?
What could it be???
Old 03-27-04, 03:03 PM
thefixitman
Is the ceiling fan controlled by the dimmer as well as the lights? If so, not good. Not good for the motor or the dimmer.
Old 03-27-04, 04:11 PM
carlosmlr
No, only the lights are connected to the dimmer, the fan is only controlled by the pull chain.
Old 03-27-04, 04:23 PM
Received 517 Upvotes on 422 Posts
Does it buzz when you turn the lights off with the dimmer?
Old 03-28-04, 05:34 PM
carlosmlr
Yes it does
