Garage Door opener reverses itself
Old 03-29-04, 03:31 PM
B
bhk
bhk is offline
Weird, we use the remote or the wall switch, either way, it closes, then reopens itself,,,,,,,,,,,,but not all the time, just some of the time..........
almost ghostlike<g>
suggestions? Door is 10 yrs old and in very good condition
Old 03-29-04, 03:36 PM
Received 1 Upvote on 1 Post
What brand is the GDO?
Does it hit the floor before it reverses and goes back up? If so, the downward limit needs to be adjusted. Perhaps you've had a bit of ground heave. The downward limit is usually just a small screw on the motor housing. Make very small incremental adjustments.
Old 03-29-04, 03:41 PM
B
bhk
bhk is offline
Lift a Door is the brand. Yes, it closes completely, full stop. then lifts again............but not all the time...
Old 03-29-04, 03:43 PM
Received 513 Upvotes on 418 Posts
Sounds like the down position or force out of adjustment. The door is thinking it has hit somthing and the saftey switch is reversing it.
Old 03-29-04, 04:27 PM
R
Adjust the downward travel back a little bit.
Old 04-12-04, 11:27 AM
B
bhk
bhk is offline
Limit dogs were broken; had to call local repair service
thanx to all for suggestions
