Installing ceiling fan. Red or white, which is hot?
Old 04-16-04, 10:03 AM
Miguello
Question Installing ceiling fan. Red or white, which is hot?
I shut off the breaker, pulled the old circline flourescent fixture down, and there are two wires. One red, one white. Am I to assume the white wire is hot, or is it the red wire. This is an old GI bill home built sometime in the mid to late 40's. Anyone know?
Old 04-16-04, 10:49 AM
Received 1 Upvote on 1 Post
If you are in North America, red is hot and white is neutral.
Old 04-16-04, 10:50 AM
scott e.'s Avatar
Typically the red wire will be the hot wire.
Old 04-16-04, 11:21 AM
Sharp Advice's Avatar
Admin Emeritus
Received 7 Upvotes on 6 Posts
John & Scott
Question:
Is it possible the white is hot and the red is a jumper wire?
Jumper wire meaning the light has two on/off switches. One on one wall and the other on another wall.
Like lights used in hallways, where the light can be turned on or off at either end of the hallway.
Or is the two wire system not possible to have dual turn on/off locations.??? Just curious.
Hello: Miguello.
Are the wires you are referring to in an electrical box?
In a conduit? and not in an electrical box.
Wires on the light fixture maybe?
Not sure to which wires you are referring to.
Kindly explain to which the wires belong. Thanks.
Trying To Learn More 2
May not be the only one here whom is confused.....
Web Site Host & Forums Monitor.
Old 04-16-04, 11:54 AM
Miguello
Thumbs up
Already done, and works fine, thanks.
