Acceptible mounting surface for electrical panel
Old 04-17-04, 08:48 AM
lekalif
Can anyone tell me if plywood,partical board,chip-board,drywall or other surfaces are acceptible surfaces for mounting an electrical panel?
If not, what is up to code and what is not?
regards,
sean
Old 04-17-04, 10:07 AM
Speedy Petey's Avatar
" plywood is pretty much standard issue. If your basement is very wet PT plywood is a good idea. Many folks don't like the PT inside their house but if your basement is that wet you're probably not spending much time there anyway.
Sometimes I like to build the plywood out off 2x4's on the flat so there is a 1" air space behind the board.
