Open Ground
Old 04-26-04, 07:17 PM
tbortiz03
Open Ground
How do I correct an open ground I have in a garage elect. outlet. The wiring is as such: from the sub panel to the first outlet (no open ground), all 3 wires connected ok, the second shows open ground and is hook up the same way from the first outles, all 3 wires, why an open ground????????
thanks tbortiz03
Old 04-26-04, 07:30 PM
Received 1 Upvote on 1 Post
Exactly how did you connect the grounding wires in the first box.
Old 04-27-04, 12:40 PM
Received 516 Upvotes on 421 Posts
Either it's not connected properly in the first receptacle box, the second receptacle or the wire is damaged in between the receptacles.
