Ground rod resistance
Old 05-04-04, 02:51 PM
scrapiron
Is there a simple way to measure the resistance of a grounding electrode? I understand that the code requires 25 ohms or less. Many thanks.
Old 05-05-04, 04:21 AM
lagunavolts
ground rod resistance
Are you being required to show certification of the ground rod?
Old 05-05-04, 05:09 AM
jughead's Avatar
There are ways to measure the effectiveness of a ground system but it takes special equipment to obtain a meaningfull reading.
Old 05-05-04, 05:37 AM
HandyRon's Avatar
You would need a special meter.
The code only requires 25 ohms or less if you have only one rod. There is no resistance max if you drive a second rod.
