Dryer Circuit Ext.
Old 05-24-04, 01:02 PM
jjrick
Dryer Circuit Ext.
I want to extend a dryer circuit to the other side of a room. There is currently 10ga / 4-wire running from the panel to the recceptacle. Can I use a junction box to extend this wire to the new location or will this not be code compliant. The box will be accessible from the basement and I would be using 10ga/4-wire for the extension which would be an additional 12 feet.
Please advise...thanks
Old 05-24-04, 04:38 PM
Received 516 Upvotes on 421 Posts
4 wire cable you are allowed to extend. 3 wire you are not allowed to extend.
You should be OK.
Old 05-25-04, 06:07 AM
jjrick
Thanks for the info
Old 05-25-04, 11:22 AM
P
You will be running a "Cable" not a "wire".
"10/3" N-M Cable indentifies a cable with 3 insulated condutors ("wires") and a bare Equiptment Grounding Conductor.
Good Luck& Enjoy the Experience!!!!!!!!!!!
