hand tool safety-battery operated?
would it be safe to use battery operated 18 volt drill while stanign in filled swiining pool? so far the only way to repiar shot of draining the pool
Certainly safer than a corded drill. But given low enough skin resistance (e.g., it's wet), 18 volts can kill you if you're unlucky enough. To do that, however, you'd have to make contact with both connections from the drill battery, and the connections would need to be with different parts of your body.
All in all, I'd say you'd need to be trying pretty hard to kill yourself. Nevertheless, let someone dry change the battery if need be. And of course keep the drill dry (mainly to protect the drill).
walkerstoo,
I always try to be a pessimist in this type of thing and would tend to err on the side of caution.
Just stick your tongue on a 9 volt transistor battery and see what less than 10 volts feels like.
An air powered drill would definitely be the right tool to use in this case.
fred, good thing YOU mentioned it.
Ya, thats my test too but there I go, being cautious again.
What if someone electrocuted themselves after I suggested it?
I agree with John on this one - you'd really have to try hard to kill yourself using a battery operated tool in this manner. You'd need to complete a circuit from the positive terminal of the battery, across your body, and to the negative terminal of the battery (current won't flow out of the positive terminal unless an equal current flows into the negative terminal). Plus the path would have to be pretty low resistance (certainly less than 2 kohm). A path to earth through your body doesn't matter.
At a guess I'd say you are more likely to be killed by a lightning strike while making your repair than by your drill battery.
There are documented cases of people being killed by a 12-volt car battery. But since the negative pole of the battery is connected to the car chassis, there's much more opportunity to come into contact with both poles of a car battery than a drill battery. I certainly would not go out and grab both terminals of my car battery with wet hands and a weak heart.
it is not the voltage that kills but the current. It takes only 4 ma to fibrulate (sp?) (make it spasam instead of pumping blood) the heart. Depending on your skin resistance, and the path the electricity takes throught the body, any voltage is potentially deadly by ohms law!
