Replacing main panel
Old 05-25-04, 07:43 PM
I noticed that some of the circuits to my main panel are ran in what I will call a cloth covered insulation rather than the plastic coverings of today. Can I continue to use these or should I pull new wires throughout?
Old 05-25-04, 08:54 PM
bhyman
If the insulation on the conductors and the cloth covering is not falling apart and is completely intact, not crackinng either, then you can use it.
Old 05-26-04, 12:54 PM
Received 513 Upvotes on 418 Posts
If there is a ground wire the you can leave it in place and use. I would not be reusing or moving it around.
