Subpanel/Cable run questions
Old 05-26-04, 01:20 PM
When running 6-3 Romex perpendicular to the joists for a subpanel (open basement ceiling), is it OK to mount it on a run of 1x3 pine? Is this method OK in most municipalities that you know of? If not, what's the preferred way - BX? Conduit? The ceiling is 7' 2" high.
Also, if I decide to call a Pro, will he take care of the permit on a small job like this or is it up to me. And will the inspector likely come to my house and check it out (in your experience)?
Thanks.
Old 05-28-04, 06:22 AM
scott e.'s Avatar
using a "running board" method is acceptable. Usually, the electrician will pull the permit, if needed. If a permit is required, then an inspection is usually required, also. As for whether or not a permit is required or if you can even do the work, is up to the state/local government in your area.
Old 05-28-04, 06:27 AM
With 6/3, code even allows you to skip the running board if you want. Although with a low ceiling, I'd be tempted to use the running board anyway.
