Wire to drip irrigation valve cut in two
Old 05-27-04, 08:52 PM
Question Wire to drip irrigation valve cut in two
We are trying to troubleshoot the drip irrigation system in a house we just bought and found one of the wires to a zone cut in half (probably by their previous gardener) and just swinging in the bushes. Is there a simple, safe way to re-join these two wires? They seem to operate 3 zones on our system so are rather important. Besides turning off the electricity to the control box, are their other safety measures? Thanks.
Old 05-27-04, 10:41 PM
It's low voltage, so few rules apply. I'd buy a waterproof wire nut (it has goop inside it) and screw it on. Or you could probably use a regular wire nut and fill it with silicone caulk after making the connection.
Old 05-28-04, 04:39 PM
I have regular wire nuts but if I go that route, is the silicone caulk you recommend the same I have to caulk the sink? Thanks.
Old 05-28-04, 05:42 PM
Use GE silicone II that will be best for outdoors.
Old 05-28-04, 05:45 PM
I have no idea what caulk you use to caulk your sink. But if it's latex caulk, then no, don't use it. Use 100% silicone caulk. JOHNJOHN's suggestion is one such caulk.
Old 06-12-04, 09:26 PM
Red face wire to drip irrigation valve cut in two
It took a while but I did get some silicone caulk as suggested to waterproof the connection and successfully re-connected the wires that were cut. Thanks to all!
