Grounding Question
Grounding Question
In a main panel is it acceptable to twist and wire nut 5 #14 bare grounds together with one connected to the ground/neutral bar due to lack of spots?????
It's fine. In normal conditions, there is no current at all on the grounding wires. And it is incredibly unlikely to have simulataneous faults on multiple independent circuits.
A better method is to compress the "end" the twisted-wires inside a lug which is bonded to the metal surface of enclosure-- very similair to terminating a #6 wire with an "approved" fitting.
Good Luck & Enjoy the Experience!!!!!!!!!!!
