electric motor woes
Old 05-31-04, 04:13 PM
boghog
electric motor woes
hello,
i have two electric motors that i'm having a problem with. one is an old Norge (i assume from a refrigerator) 1/4 hp 1740 rpm. the other is a GE 1/2 hp 3650 rpm. i'm trying to use them to turn a squirrel cage blower; the norge won't turn at full speed when a load is on it, and the GE won't turn at all with a load on. they both run fine with no load. any suggestions? let me know if you need more info from the motors.
thanks
Old 05-31-04, 04:43 PM
user X
They're probably overloaded. You might be able to reduce the load by changing pulley sizes (smaller on the motor/larger on the blower). The other problem is that the higher HP motor also has a higher RPM which works to your disadvantage in this application, so it's not like you have twice the motor with the 1/2 horse, especially if you're using the same pulley set for both motors.
Another problem may be that they're split phase motors and that the capacitor has failed. If there is a capacitor on the side of the motor, and you have a volt meter, we can walk you through the test procedure. I would try the pulleys first though.
Old 05-31-04, 06:11 PM
boghog
electric motor woes
i'll try the pulley thing and get back to you if that doesn't work. thanks so much for your assistance.
ben
Old 06-01-04, 11:12 AM
scott e.'s Avatar
you might try the ge motor an give the fan a "push" to get it started. If it runs then, it is the capacitor or possibly a centrifical switch problem.
Scott E.
