circuit breaker in 50 amp circuit
Old 06-07-04, 08:53 AM
mageac
first post
i have a 50 amp rated receptacle that im assuming is on a 50 amp circuit. i want to know if:
-what do i do in order to install a 30 amp receptacle on this circuit? do i need an electrician to install a new circuit breaker for this or is it something i can do myself? i have the infamous Federal Pacific box and I know I need to get it replaced so shoud i just wait? any input is appreciated-thanks
Old 06-07-04, 11:33 AM
Received 1 Upvote on 1 Post
Your assumption may be invalid.
A 30-amp receptacle may only be installed on a 30-amp circuit. So just change the breaker to a 30-amp breaker.
Depending on the rest of the details of your project, there may be other issues.
Old 06-09-04, 09:13 AM
mageac
thanks for the reply. i never realized that it was simply a matter of replacing the breaker in order to step down the voltage on the circuit.
Old 06-09-04, 09:17 AM
scott e.'s Avatar
The voltage stays the same, you are limiting the current (amperage) that the circuit can provide.
