pool pump installation
Old 06-12-04, 11:34 AM
Instruction says: " Use motor bonding lug to connect the motor with other bonding parts using a #8 AWG conductor as required by electrical codes."
What does that mean?
How can I determine if my cuircit line is 115 or 220/230. ??
Old 06-12-04, 12:31 PM
Ed Imeduc's Avatar
Wink
[QUOTE] Use motor bonding lug to connect the motor with other bonding parts using a #8 AWG conductor as required by electrical codes[/QUOTE
Run the #8 to a ground there. Check code for where you are.
If you dont know what to look for in the panel. Id say get a meter and read it out. Is the wire on a double breaker? That would be 220V.
ED
Old 06-12-04, 01:41 PM
How can I determine if my circuit line is 115 or 220/230?
With a voltmeter.
Old 06-12-04, 06:36 PM
All metal within ten feet (or some distance like that) needs to be bonded together and connected to the lug on the pool motor. This means the metal sides of the pool or the rebar in the concrete, any metal ladders or handrail, a metal fence surrounding the pool, etc.
