Attic Fans and GFCI
Old 06-13-04, 08:14 AM
timgeorge
Attic Fans and GFCI
In my house all of the GFCI's are run off of the same breaker. We recently added a fridge to the garage, also on the GFCI, and now attic fan blows the circuit every time.
Does the attic fan, which has exterior pentration, have to be on a GFCI circuit? If so, can I add it to another non-GFCI breaker and use a GFCI outlet instead?
Thanks
Old 06-13-04, 09:45 AM
This circuit is very seriously overloaded. Even if it didn't trip due to a ground fault, it would likely trip from time to time due to an overload.
Nevertheless, I don't recommend any fans be installed on GFCI. Anything with a large motor has the potential of tripping a GFCI. And putting a refrigerator on a GFCI circuit is typically a very bad idea if you keep food that might spoil in it.
I recommend two new circuits, one for your freezer and one for your attic fan. Code does not mandate GFCI for an attic fan.
