Old wiring being replaced
Old 06-17-04, 08:33 PM
John Doh
I have a problem that concerns this old house I'm in. I went to replace the outside front porch light but noticed the wiring going into the house and lightswitch is old wires. Its using the old 1 wire type with a ceramic "holder?" keeping it off the sides of the walls. How do I find out which wire is the "hot" one? It would seem most of the house is like this ( the kitchen has the same wiring left in for the lighting) but from the basement it looks to be all newer wiring....
Any help would be much appreciated.
Old 06-17-04, 09:38 PM
Rlfrazee
You can use an inductive "tic" tester. These are available from Home Depot or your local hardware store. Seperate the wires a few inches from one another and simply touch the wire with the end of the tester and a light will come on if it is the hot wire....RL
Old 06-18-04, 09:07 AM
Received 1 Upvote on 1 Post
The voltage tick tester is available at all home centers, usually costs less than $15, and is easy and fun to use.
Old 06-18-04, 11:55 AM
Andrew's Avatar
Received 14 Upvotes on 10 Posts
Maybe this is a stupid question, but why is it called a "tick tester"? I've been using one for years and I love it, but always wondered about the name.
Old 06-18-04, 12:12 PM
R
Because it makes a tic sound when you find the hot wire. At least some of the models do.
Old 06-19-04, 07:09 PM
Andrew's Avatar
Thanks for clearing that up.
Mine just lights up red at the probe end. Guess the ticker doesn't work anymore.
