bathroom light fixture
Old 06-18-04, 07:32 AM
skidmore27513
I currently have 1 large light fixture in my bathroom. It is one of the mirror bars with 8 lights on it. I want to replace it with 2 smaller light fixtures and I want to control both fixtures with the same light switch. I am not sure how to run the wires for this.
Should I run the wires to one light then run a small section of wire to the other light and then the wires to the switch? Or, should I split the wire and run short sections to each fixture and then run the switch from one light?
Old 06-18-04, 07:37 AM
Received 1 Upvote on 1 Post
Either way will work. The first method you described is more common.
