Converting light into outlet...
Old 06-19-04, 10:52 AM
cdecarlo
Question Converting light into outlet...
I want to turn a light in my cold room into an outlet so that i can plug my freezer into it. The cold room has cement walls and the wires for the light run through the door jam. The light doesn't have a separate switch, there is a pull string to turn it on and off. I am willing to sacrifice the light for the outlet if i have to, (I can always plug a lamp into the new outlet!)
Is there anyway I can make this conversion?
Thanks
Old 06-19-04, 12:16 PM
H
I have seen this done using a converter outlet with a light bulb type base. That doesn't mean that it's safe, or even a good idea. If the circuit to your light is heavy enough, (preferably 12-2 with ground), and there's nothing else on the circuit, you'd probably be okay replacing the light fixture with a duplex outlet. Otherwise you run the risk of overloading the circuit, and tripping the breaker (or blowing a fuse). This could easily cost you the contents of your freezer, as such things usually happen when you're gone. This should really be on a dedicated circuit, for that reason. Don't skimp on this, have another circuit ran if necessary, for both safety and peace of mind....
Old 06-19-04, 02:47 PM
Received 1 Upvote on 1 Post
As HD says, it is fairly trivial to take down the light fixture and install a duplex receptacle. It might even work okay.
