220V Circuit Question
Old 06-25-04, 05:49 AM
CA48157
I have an existing 220V 20 Amp circuit for a window air conditioner. I am interested in replacing the existing a/c with a new unit that calls for 220V 15 Amps. The existing wiring is 12 gauge. Can I just replace the 20 Amp breaker with a 15 Amp breaker and switch the recepticle with a 15 Amp version? Is leaving the 12 gauge wire in place acceptable?
Old 06-25-04, 06:55 AM
scott e.'s Avatar
if the receptacle is a 20A only, and not a 20A/15A combo unit, then you should be able to just plug in the AC and go. If this is the only receptacle on the circuit and it does not work with the AC plug, replace it with a 20A/15A combo unit. Then nothing needs rewired. The breakers protect the wiring, not the appliance.
Old 06-25-04, 09:06 AM
I agree. If the plug will fit the receptacle, then just plug it in. Does the plug fit the receptacle?
Old 06-25-04, 10:06 AM
CA48157
The receptacle is a combo, so the new unit will plug in okay. My thought was that if it was recommended to change to a 15 Amp breaker then I would change to a 15 Amp only receptacle.
Thanks
