2 speed motor-switch how?
Old 06-26-04, 01:23 PM
fishers bay
Question 2 speed motor-switch how?
I am installing a 2 speed fan and switch.
How do I wire it ?
Old 06-26-04, 02:27 PM
Received 1 Upvote on 1 Post
Attic fan? Gable fan? Window fan? Whole-house fan? Bathroom fan? Range fan? Radon mitigation fan? Crawl space exhaust fan? Ceiling fan? Room fan? Evaporative cooler fan? Personal desk fan? Radiator fan? Furnace fan? Grateful Dead fan?
Old 06-27-04, 06:56 AM
lagunavolts
John, I think you scared this one away...
Old 06-27-04, 12:12 PM
fishers bay
Cool 2 speed motor-switch how ? More info now included
I'm not scared.....
The fan is a exhaust or barn fan.
I have power to the wall the fan is mounted on, about 4 ft. away.
I plan to put the switch at the above location...metel box...4 ft. away.
Then run 1/2" flex from metel box to fan.
The switch is a on1-off-on2.
on1 is LoadA2 and LoadB2.
off is LineA and LineB.
on2 is LoadA1 and LoadB1.
The motor has a high, and a low.
The high is marked : The low is marked:
H----------------------L
Blank----5 5----Line2
Line1---- 2 2----Line1
Purple----4 4----Purple
yellow----1 1----Yellow
Line2-----3 3----Blank
My queestion is how do I tie this all together ?
Power at the box-the switch-the motor? Purple, Yellow, Line, Load ?
Last edited by fishers bay; 06-27-04 at 07:41 PM. Reason: The diagram I wrote moved when I posted it.
Old 06-30-04, 08:31 PM
W
You've scared us all away with insufficient information on an unfamiliar installation.
We've no clue of things like the ampacity of the sitch, the power rating of the fan, etc. Were the fan and switch bought together, sold to work together, or do you just have a random switch? What sort of voltage? Is this on a double pole breaker? What is your previous experience with wiring?
At best any instructions that we give you would be a shot in the dark.
For what its worth, it sounds like you have a double pole, double throw switch, and a motor that requires one of the supply leads connected to one terminal, and the other supply lead connected to one of two terminals, with the two terminals being used to select speed.
-Jon
Old 07-01-04, 05:05 PM
Rlfrazee
If you give us the fan manufacturer, model#/serial# and switch type and manufacturer then we have some hope. Key thing here is, wire it wrong, and you will let the smoke out of the fan motor.... thats a bad thing......RL
Old 07-01-04, 06:07 PM
Received 477 Upvotes on 393 Posts
Connect the white wire to terminal 2. Connect the hot to the lineA on the switch. Connect the loadA to terminal 5 for low speed. Connect loadB to terminal 3 fro HI. Connect the purple and yellow wires to the terminals indicated 4,1.
Old 07-02-04, 04:40 AM
fishers bay
Wink 2-speed
Thank You !!!!!!!!! Thank You!!!!!!!!!!!!
This Forum Is The Best !!!!!!!!!
Old 07-02-04, 04:19 PM
W
I would _strongly_ urge you to answer Rlfrazee's questions. My opinion is that joed's answer might get you fan working, but that the install would not be safe, since only one of the hot leads is witched. If the switch that you have seems to be a double pole, double throw switch, so you should be able to switch _both_ hot leads, with no power going to the fan.
Additionally, you have not provided any information that makes it clear that this switch is safe to use with this particular load. If you use a switch that cannot tolerate the inrush current of the motor that it is supplying, then the contact electrodes can corrode and cause poor connections, or the contacts can even _weld_ making it impossible to disconnect the load.
-Jon
Old 07-04-04, 08:51 AM
fishers bay
Thumbs up 2-speed motor
Thanks again for all the advice !
I consulted a local expert and resolved my question.
The motor is also able to be reversed....the yellow and purple.
Now its just basic line A---line B.......HI and LOW.
Next time I will provide all the details @ first posting.
P.S. The project is complete.
Thanks
