Installing a Wall Control for a Ceiling Fan
Old 07-03-04, 07:25 PM
mlessley
Cool Installing a Wall Control for a Ceiling Fan
Can anyone help with installing a wall control for a ceiling fan?
Old 07-03-04, 07:35 PM
Received 1 Upvote on 1 Post
Yes. Tell us the make and model number of the fan control, and the wires in the box that you have to work with. Also tell us if your fan has a light.
Old 07-03-04, 07:59 PM
mlessley
Talking Whoops! Left out the most important info
This is my first time attempting to install something electrical.
The make and model of my fan is a Mikado 54MI with a Wall Control.
54-inch, 5-blade construction
14-degree blade pitch
Command System 2000 Wall control unit
100-watt halogen light fixture (bulb included)
188 mm x 20 mm aluminum motor
80-inch lead wire
The wires on the wall control unit are 1 light green (with yellow stripe) and 2 black. The wires to the motor/light fixute are white black and green.
Old 07-03-04, 10:00 PM
Since you referred to this as a wall control, I assume you are installing this in an existing electrical box in an existing wall. And I am also assuming that this existing electrical box has existing electrical wires in it. Please describe those wires by color and count.
Or is this a brand new installation where you will be running brand new wiring in the wall?
Finally, what city do you live in?
