what is common
Old 07-04-04, 10:00 AM
streetrodder
what is common
what is common in elctrical wiring and how is it used?
Old 07-04-04, 10:56 AM
R
Whay do you ask? Have you seen it used in a certain way and want to know what it means?
Old 07-04-04, 04:01 PM
Andrew's Avatar
Received 14 Upvotes on 10 Posts
I have heard the neutral referred to as the "common" wire. It's function is to return the electricity to it's source.
Old 07-04-04, 04:33 PM
Received 1 Upvote on 1 Post
"Common" is not a precisely defined term in electrical work. However, most people understand that, informally, it usually refers to what most people call the "neutral" wire, or the "return" wire. Officially, it's called a "grounded" wire, but only an electrician could love that term--most people would be confused by that term, thinking we're talking about the "grounding" wire.
Street, if you give us the larger context of your question, we can help more.
Old 07-05-04, 06:44 AM
W
Another way in which the term 'common' is used in electrical wiring is for three way switches. One of the terminals will be called the common terminal, and the other two terminals will be called the 'traveller' terminals. The common terminal is _always_ connected to the switch blade, and the traveller terminals are selectively connected to the switch blade by the position of the switch.
-Jon
Old 07-05-04, 10:34 AM
How could we have overlooked that? Thanks for pointing that out Jon.
As I say, context would be good.
