Installing outlet in vinyl siding
Hi, looking for guidance on the best way to install an electrical outlet in vinyl siding. Can I just cut the vinyl to fit the box and caulk around it? Should I use a recessed mounting block? If so what's the best way to fit the block (with its tabs) into the siding? Any help is greatly appreciated.
You could try one of these
http://www.aifittings.com/whnew41.htm
or these
http://www.aifittings.com/whnew9.htm
or these
This is my "T-O-T-T" for installing a"out-door" fixture outlet-box with vinyl-siding as the exterior wall-finish ( "new work")----
drill a hole in the vinyl siding using a hole-saw with a diameter approx. equal to the diameter of a 3-1/4" octagon box----assemble together a 3-1/4" octagon extension box, a "1900" ring-cover, and a "1900" O-B ( X-B on to R-C, R-C onto O-B).
Screw the "1900" O-B onto a 2" x 4" cleat, set the cleat between the studs so that the front edge of the X-B is flush with the exterior finish, and "nail-in-place".
When the fixture is mounted, it will bear against the box only, not the vinyl siding
Outlet on vinyl siding
PCBOSS
you have the right anwser to this question. You need a outlet cover box that will allow the siding to move back and forth.
L.M.S
L.M.S
