Dead outside plug!!
Old 07-09-04, 12:49 AM
Dead outside plug!!
I was using my outside plug and it tripped the GFI breaker in the panel. It controls my bathrooms and outside plug. I turned it off and on, the bathroom plugs are working, but one plug in kitchen and the outside plug is not working. How can I remedy this problem?
Old 07-09-04, 05:34 AM
R
If there are no GFCI Receptacles that are on the circuit that may have tripped (someone may have installed one even though there is a GFCI breaker), then you will have to examine the receptacles themselves, looking for a wire that may have become disconnected.
Old 07-09-04, 09:59 AM
Outside Plug
Thank you for your response, would that account for why only 1/2 the plug not working in the kitchen and the outside plug. The bottom half of kitchen plug okay top dead.
Old 07-09-04, 12:33 PM
Received 1 Upvote on 1 Post
Yes, a failed connection could cause half of each receptacle to be dead.
Old 07-09-04, 01:41 PM
Received 513 Upvotes on 418 Posts
Sounds like a multiwire circuit. Look for a second breaker.
Old 07-09-04, 01:58 PM
Joe, in the U.S., this multiwire circuit serving split receptacles would be required to be controlled by two breakers with a common trip lever. Does Canada have a similar requirement?
Old 07-09-04, 09:14 PM
Smile Re Outside Plug!!!
You are all just too wonderful!!! Thank you for your help.....I turned the breakers off and on for all counter plugs and it worked, thank you for all your advise you saved me a $55.00 service call. Well Done!!!!!
