Gfci
Old 07-09-04, 09:52 AM
rls
Gfci
HELP!!!!!!!!!!
The GFCI in my bathroom tripped and will not reset. I pulled it out and checked the wiring with a voltmeter and found 115 volts between hot (black) and ground. 15 volts between black (hot) and white (neutral). Is this correct?
Old 07-09-04, 10:17 AM
mgb
mgb is offline
Did you test between the black and white on the line side of the gfci? If so then you have a bad connection somewhere between there and the panel. Did you have something plugged in when it tripped?
Old 07-09-04, 10:46 AM
rls
I didn't have anything plugged in. My wife tried to run the blowdryer and it didn't work. It's been raining a lot but thats the only circuit that is down.
Old 07-09-04, 11:05 AM
Received 1 Upvote on 1 Post
Sounds like an open neutral. This is usually a failed backstab connection of a white wire, somewhere (anywhere) on the circuit. Probably has nothing to do with GFCI.
