Standby Generators
Old 07-11-04, 09:37 PM
Standby Generators
Has anyone had a fully automatic standby generator installed for
your home?
They are located outdoors and are hooked up to the home's
natural gas. They begin working within seconds of a power outage.
The power they supply are from 7KW to 12KW for an entire home.
The cost installed runs from $3,000 to $5,000.
The cost is high. Any other pro's or con's?
Old 07-12-04, 04:20 AM
HandyRon's Avatar
It's a great idea if it is sized and installed properly.
12kW is approximately 50A 240/120V single phase. You home is probably 100 or 200A 240/120V single phase. Be sure that you do not overload the gen as it will be connected to the whole house.
Old 07-12-04, 06:02 AM
The backup generators I have seen come with a subpanel connected to the transfer switch. The idea is you move only selected critical circuits from the main panel into this subpanel. In a power failure only these circuits get backup power, the rest of the main panel stays dead.
Old 07-12-04, 06:28 AM
HandyRon's Avatar
You will have that choice of either the entire house with a single automatic transfer switch, or a load side subpanel as described by mikewu99.
The smaller gens would benifit from the subpanel idea for obvious reasons.
