15A outlet on 20A breaker
Old 07-13-04, 10:41 AM
kcmere
Is it possible to put a 15A outlet in the middle of a line of 20A outlets. I am wiring a woodworking shop and on a 20A breaker I was going to wire all of the boxes with 20Aoutlets. However, someone gave me some 15A outlets left over from a project they were doing so I thought I might use them if possible in a couple of boxes that one have heavy loads running to them, but it just so happen that they are in the middle of a line of 20A outlets.
Old 07-13-04, 10:42 AM
Yes, you are allowed to use 15 amp receptacles anywhere on a 20 amp circuit, as long as it is not a single 15 amp receptacle as the only outlet on the circuit.
However, if these are used receptacles then I advice that you buy new ones.
Old 07-13-04, 11:15 AM
If these are high-quality receptacles, then go ahead and reuse them. Otherwise, why try to salvage a used 39-cent part.
Old 07-13-04, 11:20 AM
kcmere
Thanks for your thoughts. They are all new receptacles.
I was also going to start each run of outlets with a GFCI receptacle. Is there going to be much difference if I start a run with a 15A rather than a 20A GFCI outlet?
Old 07-13-04, 11:22 AM
Only to your wallet.
