Code Question
Old 07-13-04, 11:48 AM
L
Code Question
Is there a maximum number of ELs that can be used with Sched 80 PVC conduit (1 1/2 in) and #2 THHN Copper? My subpanel project needs a few 90 degree turns to get to a large enough knockout in the panel without tearing into the wall cavity completely.
Thanks
Leslie
Old 07-13-04, 12:13 PM
Received 1 Upvote on 1 Post
Can't have more than 360 degrees of bends between pulling points. Even so, you probably want to limit yourself to 270.
P
Not to exceed the equivalent to four 90-degree bends.
Old 07-13-04, 01:03 PM
L
A pulling point being a place to grab wire and pull from. So is the removable cover type El is considered to be a pulling point?
Thanks
Leslie
Old 07-13-04, 01:19 PM
mgb
mgb is offline
Yes it is.
Old 07-13-04, 01:37 PM
L
Originally Posted by mgb
Yes it is.
Perfect. Thanks for a quick response. It will make the project much easier to finish using those ELs.
Leslie
Old 07-13-04, 01:44 PM
mgb
mgb is offline
You're welcome. Good luck!
