Junction box for 10-3 wiring
Can I use a junction box to wire a dryer with 10-3 wg? In other words, I need to run 60' of wire, but I didn't want to buy 100'.
Received 0 Votes
I'm not sure that I understand the question.... If you're asking about using a junction box to put a splice in, you must keep the box accessable (not behind a wall covering, etc.), but that's an acceptable way to splice wires. If you're asking if you can splice into an existing circuit instead of running a wire to your panel, then you're asking for trouble. I'm not well versed on code, but I believe you would want an electric dryer on its own circuit. I would, anyway!!
Received 0 Votes
If the existing cable has four wires (perhaps unlikely if run prior to 1996), then yes, you can certainly extend it (in a permanently accessible junction box). If the existing cable only has three wires, then run the whole 100 feet.
As HD says, this is only wise if you are merely moving a load rather than adding a load.
