How "accessable" must j-boxes be?
Old 07-20-04, 06:16 AM
rsanford
Getting closer to starting my project to finnish the attic (3rd floor). One question before I go and buy a bunch of wire that I might not need. Currently, there are 9 junction boxes in the floor joists of the attic used to service the second floor. The attic is a half story with low rafters so only finishing the center portion will be practical. Here's the question:
All of the junction boxes exist in the outside perimeter that will not be finished. I plan on building in several access doors to use this outside area for a crawlspace. Would such access be enough for the j-boxes? Thanks!
Ryan
Old 07-20-04, 06:25 AM
Received 1 Upvote on 1 Post
Yes, the access doors are acceptable.
Old 07-20-04, 06:26 AM
mgb
mgb is offline
I believe the NEC uses the term "Readily Accessible". So I would say yes.
Old 07-20-04, 06:47 AM
Different sections of the code require either "readily accessible" or "accessible". They have different definitions. I think junction boxes need only meet the lower standard of "accessible".
