Adding 50amp breaker to subpanel
Old 07-23-04, 10:46 AM
workingonmyhome
I am running a new 220 line to a 50amp breaker for a range. An electrician is coming to do the hookup.
The main panel is full. It is outside. We have a subpanel in the house with space/rooom. Is there any problem with leaving the exising 30amp breaker and outlet (it won't be used and hidden by cabinets) and adding the 220/50amp breaker to the subpanel?
Old 07-23-04, 11:00 AM
mgb
mgb is offline
No problem that I'm aware of but I would at least remove the wires from the shut off breaker and tape the ends. Also tag the wires as to what they fed so the future residents will know.
Old 07-23-04, 01:05 PM
workingonmyhome
Thanks mgb for the quick response. It is good to have availability to smart folks.
