oven help
Old 07-23-04, 03:02 PM
bullseye
Question oven help
I have a jenn air built in oven that I got used from a friend of mine.The problem is that once it's all hooke d up after about a minute the LED screen flashes F1 and beeps.............
Any thoughts?
Thanks in advance
Old 07-23-04, 07:24 PM
bullseye
Anybody???????????????
Old 07-23-04, 07:39 PM
G
Received 2 Upvotes on 2 Posts
Check out the Jenn air web site. With the model number you can download a manual, contact customer service etc.
Old 07-24-04, 05:35 AM
Rlfrazee
Hello bullseye looks like the appliance savy people are on vacation, actually you need to ask this on the appliance forum. Scroll down to "Household and Cleaning" bet you get more detailed help. Here is what I know. Your Jenn Air is actually a division of the Maytag corporation. Not sure how the models differ over the years. In newer Jenn Airs the fault code you are recieving "F1" can mean two things 1.) Watch Dog on control board faulty 2.) Touch membrane is defective. To determine which one disconnect the ribbon strip, if the fault goes away your membrane is defective if fault remains the board may need replacing. Also sent you a private message check it out......RL
Old 07-25-04, 07:49 AM
bullseye
thanks for the help, I really appreciate the info............
bullseye
