Multi-wire circuit questions
Old 07-23-04, 04:58 PM
Kray
Couple of questions about the requirement for double pole breaker and pigtailed neutrals:
1. Is a double pole breaker always required for a multiwire circuit? Could be wrong but I thought I saw a response awhile back that said that the requirement applies when the two hot wires run to the same device, but not when they do not. I have a multiwire circuit where the two hots power two separate outdoor circuits, and do not run to the same device. It currently has a double pole breaker and I have no reason to change it, but was just wondering if the requirement is "absolute."
2. Also, are pigtailed neutrals also always required for a multiwire circuit or are there any circumstances where they are not? In the circuit described above, I do have an "unpigtailed" neutral that I can fix if required.
Thanks
Old 07-23-04, 05:20 PM
Received 1 Upvote on 1 Post
It is sometimes, but not always, required. But it is always a good idea.
True. In technical jargon, substitute the word "yoke" for "device", since a duplex receptacle is really two devices on one yoke.
Yes, pigtailed neutrals are always required when the neutral is serving two hots.
