Keep blowing off fuse at main panel
Old 07-23-04, 07:43 PM
sympac
Hi there....
I am having trouble installing the lamp described above.
I have followed the installation instructions properly but, I keep blowing the fuse at the main panel.
There are two wires, one coming directly from the main panel and the other coming from the switch on the wall, when I connect the wire coming from the main panel, no problem. The problem happens when I connect the wire coming from the switch on the wall.
Obviously, I must be connecting the wires wrong so the fuse keeps blowing off.
Can anyone pls help with this issue?
Old 07-23-04, 08:27 PM
Received 1 Upvote on 1 Post
described above
Described where?
You need the standard switch loop wiring. Make these connections at the light fixture:
  • Connect black from power cable to white from the switch. Neither of these wires connects to the light fixture.
  • Connect black from the switch to black from the light fixture.
  • Connect white from the power cable to white from the light fixture.
Old 07-23-04, 08:32 PM
green jacket's Avatar
What type of fixture is this?
Is the box metal, it so are there grounding wire attached at teh back or on the clamps? If the wiring is old, the condition of the insulation introduces another factor in the equation.
What else is on the circuit? Have any other changed been made?
Note that your details are our key to helping.
gj
