outlet problems
Old 07-28-04, 11:35 AM
arbratsch
outlet problems
My bathroom outlets are not working in any of my bathrooms. The lights and fans all work but the outlets do not. I can only find one GFI in my house and that is in the garage, it was not tripped. I checked all the breakers and even shut them off and reset them, this did not help. I am wondering what else would cause this problem. My daughter did tell me that there was a short power outage and I believe that is when they stopped working.
My house was built in 1978 was there no code back then about having GFI's next to all water sources? I am kinda shocked I only have one in my entire house
Old 07-28-04, 12:04 PM
HandyRon's Avatar
Don't give up yet. Check on the oitside of your house and in the basement and garage for this GFCI.
It is almost always the culprit.
Old 07-28-04, 12:40 PM
arbratsch
do you have any suggestions as to how to locate the GFCI?
Old 07-28-04, 12:50 PM
Received 1 Upvote on 1 Post
It's usually just a thorough search of every inch of every wall of every room and outside area of your house. You usually have to move a bunch of stuff around to get a good look. Start in the areas that Ron suggested. Be sure to check the other bathrooms and the front and back porches too.
Old 07-28-04, 02:09 PM
arbratsch
I've checked every room no GFCI could there be another problem?
Old 07-28-04, 03:40 PM
Maybe your GFCI went bad. As the next step, I'd try replacing it, especially if the same one has been there since 1978.
Old 07-28-04, 03:42 PM
R
Don't replace the GFCI until you decide if there is power getting to the GFCI.
