3 way switch - differentiate
Old 08-08-04, 09:07 AM
How do I tell the difference between a 3 way and a regular on/ off (2 way?) switch??
thanks,
Frank
Old 08-08-04, 09:13 AM
The simplest way is to look at the lever on the switch. If it says "on" and "off" on it, it's a single-pole switch. If the lever is blank, then it's either a 3-way or a 4-way.
Old 08-09-04, 06:14 AM
If you have the switch in your hand a regular on/off will only have 2 screws + maybe a ground. A 3way will have 3 screws and a 4 way will have 4 screws.
Old 08-09-04, 06:26 AM
Not always correct. I have seen switches that have two screws per connection. A two way switch has four screws (plus ground). Enabling the connection of two wires without the need for a pigtail.
