Formula to calculate amps per hour?
Old 08-09-04, 09:45 AM
W
Is it possible to use a formula to calculate the approximate number of amps per hour this pair of lights will use?
http://www.montanajacks.com/index.as...ROD&ProdID=288
Thanks,
William
Old 08-09-04, 09:55 AM
R
Of course. What size battery does an ATV have? 12 volts?
Old 08-09-04, 10:03 AM
W
Yes...12 volts. I would use this battery to power the lights...
http://www.motorcyclebatteriesusa.co...asp?battery=20
Thanks,
William
Old 08-09-04, 10:11 AM
R
Two 35 watt bulbs is 70 watts.
Power = volts times amps.
This yields 5.8 amps at 12 volts, 5.14 amps at 13.6 volts.
Based on your other posts (you really should have combined them all into one post), with your 10 amp hour battery you will get somewhere between one and two hours of light.
Old 08-09-04, 11:53 AM
W
Thanks for the prompt response.
William
