Change 220 To 110 Yep Thats Right!!
Old 08-16-04, 07:21 PM
dansdad
I now have a freestanding electric stove which I am changing to gas. Question... I need to change the 220 to 110 as 110 is all thats needed to power the clock, lights, etc. and I could use the 220 elsewhere down the road. Whats the best way to do this? Thanks...Dave
Old 08-16-04, 07:34 PM
Received 1 Upvote on 1 Post
You could, but you need to change almost everything: the breaker, the connections in the panel, the receptacle. It's probably just slightly harder to run the new circuit you need from scratch. At least that way, the option to return to an electric stove remains.
Old 08-17-04, 05:13 AM
R
I agree with John. Leave the 240 outlet in place. Run a new outlet for the stove.
Old 08-17-04, 05:28 AM
W
However, if it happens to be really difficult to pull the wires to the correct place, you might find it _easier_ to work with the existing wires and make the correct new connections at either end. As John and Racraft say, this will essentially be as much work as installing a new 120V circuit and leaving the 240V circuit in place...with the exception of not having to pull the cable from your box to the load point.
To do this, you will need the following:
a new 20A single pole breaker that fits your panel
12ga wire for jumpers
wire nuts, split bolts, or insulated screw terminal connectors suitable to connect 12ga wire to the wire currently in place
A 15A or 20A duplex or quadruplex outlet, or two duplex outlets
A faceplate that will mount the outlets on your current outlet box
Then simply run as a new circuit, but instead of connecting the breaker to a cable going to the new outlet, you run breaker to 12ga jumper to old wire, then old wire to jumpers to new outlets.
You will use the black and white wire from the old cable, and cap off the red wire at both ends. If you have space, you can simply leave the old double pole breaker in the panel, but make sure to disconnect both wires connected to it. If you need to take the old double pole breaker out, then you will need to get a cover plate for the extra hole.
-Jon
,You will also need
