Convert 3-way switch to 2-way
Old 08-20-04, 11:26 AM
cjsuther
Hi,
I have a dock in my backyard with lights on it. Currently the lights are controlled by a 3-way circuit, load at the end of run. One switch is located inside the house, the other is outside near the dock in a weatherproof enclosure.
I want to remove the outside switch and make the inside a simple two way switch. Is there an easy way to accomplish this?
Thanks,
-CJ
PS: I want to do this because I want to install X10-controlled lighting here, and I can't find a weatherproof switch like the one I have now that's X10 compatable.
Old 08-20-04, 12:10 PM
R
Just remove the outside switch and connect one of the switch wires to the hot wire going to the lights. Cap the other switch wire off with a wire nut.
