Dimmer Wiring
Old 08-25-04, 09:56 AM
diyagain
Dimmer Wiring
I am tring to use a dimmer on my recessed lighting. The current configuration is there are two switches beside one an other one controlling an outlet and the other running the lighting in question. The only wires goin to the switch are 2 black wires one in and out i presume but how do i wire the dimmer into that?
Thanx
judd
P.S the other switch has a red wire running to it then a black running out to the wire nut, from there (the wire nut) the black pigtails to the switch in question then runs to the light.
Old 08-25-04, 10:21 AM
R
The two wires on the light switch get connected to the dimmer switch.
Old 08-25-04, 11:31 AM
Received 1 Upvote on 1 Post
To expand a bit on Bob's post, the old light switch has two wires, the new dimmer switch has two wires. Connect the one-to-one in either order. The dimmer probably also has a grounding wire which you should attach to the grounding connections in the box (if any).
Old 08-25-04, 02:45 PM
diyagain
re:
Ok i did try to connect the black to either and i got nothing i am wandering is it a single post or dual, also does the ground have to be hooked up for the dimmer to work?
thanx
judd
Old 08-25-04, 02:47 PM
R
You must connect one black wire to one lead, the other black wire to the other lead. No, you do not need the ground connected for it to work.
I siggest that you verify that you have power going into the dimmer.
