Need longer screws for Culter Hammer panel cover
Old 08-31-04, 12:29 PM
I've drywalled around the breaker box and need longer screws to support the panel cover. HD doesn't have them. Can anyone suggest where I could find longer screws -- probably 1-1/2'?
Old 08-31-04, 01:04 PM
Received 1 Upvote on 1 Post
I can see why Home Depot doesn't have one and a half foot screws, but they or any hardware store should easily have one and a half inch screws. Probably not in the electrical aisle, but they should be in the hardware aisle.
But code requires that the panel lip be no more than 1/4" behind the face of the drywall. You should have moved the panel out a bit before you drywalled.
Old 08-31-04, 01:24 PM
Thanks, I'll go with the 1-1/2" screws The inspector didn't say anything about moving out the panel 1/4" or so. I guess I'll wait and see if I need to change anything for the final sign off. The cover will rest on top of the drywall. How could I move the panel out now? Can I place any sort of insulation or material around the box/drywall to make up the 1/4" difference?
Old 08-31-04, 04:13 PM
Speedy Petey's Avatar
It's not that you need to move the panel 1/4". It's that the panel should be set back in the rock no more than 1/4" If you need 1.5" screws for a CH panel it is set back way too far.
Will the inner cover even be near the breakers once installed?
Old 09-01-04, 05:52 AM
Luckily, for the Cutler Hammer design, the panel cover is in two pieces screwed together. One surrounds the whole box and the other just surrounds the breakers. I was able to move the one surrounding the breakers back toward the wall a bit so that it fits nicely around the breakers. Everything seems to look fine. The 1" screws I'm using seem to work OK, but they are only using about 1/4" of the threads to hold the entire panel cover.
