Wiring Question
Old 08-31-04, 07:55 PM
dclapper
Wiring Question
I have a generator with a 120/ 220V 4 prong twist lock outlet. I want to run a small room AC unit that has a 3 prong grounded receptacle, t-slot plug and runs on 220V. Is it possible to make a cable up to run this?
Thanks
Dale
Old 08-31-04, 08:46 PM
sjr
If I understand your post correctly, your a/c has a 3-prong plug and you want to connect that to your generator which has a 4-prong receptacle. Photos would help.
You should just be able to obtain a matching 4-prong plug (from local electrical supplier or Home Depot) and replace the plug. Just be absolutely certain that you know which wires goto the which prongs on the old a/c plug.
You would connect the two hot leads and the ground to the corresponding terminals on the new plug. I do not believe there would be a connection to the grounded (neutral) prong--though perhaps others on this forum can advise whether it would be wise to attach the ground wire from the a/c to both the ground and neutral prongs of the new plug.
While the cable/new plug should work, that is not a guarantee that the generator would have enough capacity to run the a/c. You would need to check on this before attempting to connect it.
Old 09-01-04, 06:01 AM
R
I would not replace the plug on the air conditioner, unless I no longer planned to use the air conditioner anywhere else. I would make up a short cable to connect the two. You can buy the cable and the parts at either an electrical supply store or even most home centers.
Old 09-01-04, 07:13 AM
Received 513 Upvotes on 418 Posts
You should be able to buy the cable and plugs at an electrical supply. I don't know if HD will have them.
