screw pulls out of outlet box
I replaced an outlet in an existing outlet box (it's nailed to a stud) and now the top screw of the outlet pulls out. What is the best way to correct this so the top screw of the outlet remains screwed into the box?
A trick I used to use on stripped screws back when I was into radio controlled cars, was to put a light coat of cyanoacrylate (superglue) on the inside edges of the stripped part of the screwhole. DON'T fill the hole, just coat the sides lightly - use a toothpick, if that helps. When it cures, you've got yourself a brand-spankin' new hole that should accept the original screw without a problem.
