Keeps tripping the circuit breaker
I have a swamp cooler for my business location, 110 volt motor. Whenever I turn on the swamp cooler, the circuit breaker is tripped 3 or 4 seconds later. The cooler used to be working fine before but I just found out that the store was not as cool as before.
What seems to be the problem? Any advice would be appreciated. Thanks in advance. Andy
If the vent fan is operating on the same circuit as the cooler motor & it is starting to seize then that may be the problem.Do you have access to an amp meter? If so I would check both motors amp draw with what is stamped on each of their nameplates. If there is no nameplate for each motor there should be one that give the combined amp draw for both.
