installing wattmeter on generator transfer switch
Old 09-09-04, 09:35 PM
stanstuf
Question installing wattmeter on generator transfer switch
I took everyones advise and installed a transfer switch for my new 8000 watt generator.The switch I used is a double throw switch .I want to install a wattmeter so I will not over load the unit .I need information as to basics of the proper installation.(what meter,where to install ,etc). The gen is rated @55amps @ 120 volts and 27.5 amps @220 volts . Any help would be appreciated
Old 09-10-04, 01:31 PM
HandyRon's Avatar
Install a 7.5kW watt meter minimum, such as http://www.nooutage.com/mb75.htm
It would go on the load side (output) of the transfer switch.
