Max number of Outlets?
Old 09-15-04, 08:43 AM
W
Is there a maximum number of of recepticles allows on a single 20 amp breaker?
Phil
Old 09-15-04, 09:29 AM
P
If your question pertains to "general-purpose" receptacle-outlets connected to a 20-amp Branch-Circuit,You can connect as many receptacle-outlets as you need, provided that the sq.-ft. floor-area of the room/rooms in where they are located does not exceed 800 sq.-ft.
Good Luck & Enjoy the Experience!!!!!
Old 09-15-04, 09:50 AM
Received 1 Upvote on 1 Post
Phil,
Although the national electrical code imposes no restrictions on this, some local codes do, so it's always wise to check locally. If there are no local codes, the standard rule of thumb is to put no more than 10 outlets on a 20-amp circuit. Depending on your circumstances, there may be many valid reasons to go above or below this rough number.
Old 09-15-04, 11:19 AM
I
The Canadian Electrical Code says up to 12 devices (lights/sockets) on a single circuit. I would say itís a pretty good guideline. In my experience, if you need to put more than 8 to 10, you need to re-think the wiring layout.
Old 09-15-04, 11:53 AM
Good point impeyr. I should have said that the U.S. national code imposes no restrictions.
Old 09-16-04, 02:54 PM
Commercial electrical is limited, something like 1.5 amps per outlet.
So you would max out a 15 amp breaker with 5 duplex receptacles, IF I am recalling the details correctly AND they haven't changed in the intervening years.
Old 09-16-04, 04:42 PM
R
How do you get 5 as an answer if starting with 15 amps and 1.5 amps per recepticle? Is this new math?
Old 09-16-04, 05:06 PM
Okay, I should have said that the U.S. single-family residential national code imposes no restrictions.
As far as I know, for purposes of article 220, a commercial duplex receptacle must be counted at 180 watts. That's for both halves, not each half separately. The code says "for each mutiple receptacle on one yoke".
Old 09-17-04, 09:26 AM
P
If a duplex receptacle contains 2 outlets then each duplex would be limited at 3 amps each and then Steve's math would work. Don't know if the electrical terminology is correct, but it would make the math work.
Old 09-17-04, 09:41 AM
That makes the math work, but the answer is still incorrect.
