no power
Old 09-16-04, 05:33 PM
tkotitan
Question no power
Help. I have two rooms with no power,lights ,outlets.Ihave checked the fuse and its okay one fuse for both rooms.What next ?: I am new to this any advice would be helpful Thanx
Old 09-16-04, 05:39 PM
R
First things first. Try a new fuse. If it still doesn't work then buy a recepticle tester and test each recepticle. Report back the findings.
Old 09-16-04, 05:50 PM
tkotitan
fuse switched
checked outlets nothing could it be in panel?I switched fuse I used a circuit tester on the outlets
Old 09-16-04, 05:55 PM
R
What kind of "circuit tester " did you use, and what were the results.
Also, do you know if there are any circuits on the fuse that are working?
